CSS class in {snp_main_nav}
Claus's avatar
Claus
3 years ago
Claus's avatar Claus
… <ul> <li><a{if segment_1 == ''} class=”nav”{/if} href=”{homepage}”>Home</a></li> <li><a{if segment_1 == 'about'} class=”nav”{/if} href=”{path='about'}”>About</a></li> <li><a{if segment_1 == 'blog'} class=”nav”{/if} href=”{path='blog'}”>Blog</a></li> <li><a{if segment_1 == 'contact'} class=”nav”{/if} href=”{path='contact'}”>Contact</a></li> <li><a{if segment_1 == 'testing'} class=”nav”{/if} href=”{path='testing'}”>Testing</a></li> <li><a{if segment_1 == 'testing_2'} class=”nav”{/if} href=”{path='testing_2'}”>Testing 2</a></li> </ul> …
The class=”nav” is only assigned to the very last entry in the list. How is that possible? I want to create a class for the links in the menu.
Claus
Jared Chesebro's avatar
Jared Chesebro
3 years ago
Jared Chesebro's avatar Jared Chesebro
The nav class will only be applied when the condition of your if statements are met.
What you have:
<li>
    <a{if segment_1 == 'testing_2'} class="nav"{/if} href="{path='testing_2'}">Testing 2</a>
</li>
To always add the nav class you need to remove the if statement all together.
Claus's avatar
Claus
3 years ago
Hi Jared,
I inserted the line you posted exactly as it was, but then {title} and {page_content} are not being rendered anymore.
Claus
P. S.: Btw, how did you manage to include this code excerpt here with formatting and highlighting?
Rob Allen's avatar
Rob Allen
3 years ago
Rob Allen's avatar Rob Allen
Claus, when you post click the link “Use Markdown for rich formatting.”, that will give you formatting options.
Claus's avatar
Claus
3 years ago
{exp:channel:entries channel="einfuehrung" limit="1"} <h4> {if page_heading} {page_heading} {if:else} {title} {/if} </h4> {page_content}
doesn’t work anymore.
Claus's avatar
Claus
3 years ago
Jared,
the code you gave me contains errors:
<li><a href="http://{path=%27testing_2%27}%22class=%22nav{if" class="nav{if"><b>T</b>esting 2</a></li>
