First segment as /themes
October11's avatar
October11
3 years ago
October11's avatar October11
Hi friends,
In 10+ years I’ve been using EE, I’ve never run across this issue.
Basically, I have a /themes page on my website, and I’m getting a “Directory access is forbidden.” — since I guess EE is hitting its own /themes folder.
I’ve tried having it as a template group, using routes, etc.
Any suggestions on how to go about this?
Rob Allen's avatar
Rob Allen
3 years ago
Rob Allen's avatar Rob Allen
You could rename the /themes folder and update URL and path to it in Settings, but updating EE might re-add a /themes folder? (I’ve not tested this).
? 1
October11's avatar
October11
3 years ago
That worked perfectly, Rob! Thank you.
Will make a note for the /themes folder for when updating.
Rob Allen's avatar
Rob Allen
3 years ago
Glad you got it sorted.
