Call to a member function getField() on null in ee/ExpressionEngine/Addons/fluid_field/ft.fluid_field.php:158 when using Preview
Giraffentoast's avatar
Giraffentoast
3 years ago
Giraffentoast's avatar Giraffentoast
Seeing above error when using the Preview functionality.
Enabling all error output leads to this notice
Undefined offset: 844 ee/ExpressionEngine/Addons/fluid_field/ft.fluid_field.php, line 158
Thought this is due to some Fluid field that had been deleted, so I tried to filter out the ID (field ID 844). After doing so same error with different ID came up. Looking at the existing Fluid field IDs I noticed that the IDs that cause the undefined offset seem to be bogus IDs, since our Fluid field IDs end at something like 200.
As a quick fix I added this line to the ft.fluid_field.php at line 157 - obviously no real fix, but it works for now.
if($id>400): continue; endif;
EE version is 7.2.12 with no additional plugins/add-ons.
Any idea what’s causing the original error?
Thanks: Lars Schwarz
3 years ago
Hi Lars,
Thanks for posting this. We did just push an update yesterday that will likely fix as part of the 7.2.13 release. Any chance you can update and confirm this error is no longer present?
-Tom Jaeger
? 1
Giraffentoast
3 years ago
Hey Tom,
Indeed! Updating to 7.2.13 and reversing my dirty quick-fix fixed that issue.
Thanks: Lars
