403 error
Claus's avatar
Claus
about 3 years ago
Claus's avatar Claus
after modifying a template, I am getting the error on the frontend ‘Directory access is forbidden.’ How can I fix this? I’m running EE 7 on a local XAMPP environment. I wanted to insert an img tag with the image path {base_path}/images/uploads/.
TIA,
Claus
Russ K.'s avatar
Russ K.
about 3 years ago
Russ K.'s avatar Russ K.
Hi Claus,
I don’t use XXAMP specifically, but my image links would look like this: {site_url}images/uploads/whatever_my_image_name_is.png
Also, For what it is worth… the structure I use is to keep all of my own content seperate from the EE Directories… at my root level, I have an “Assets” folder and inside of that I have an “images” folder and I point my file upload directory to that. so for me, that link would look like: {site_url}assets/images/whatever_my_image_name_is.png. I think that may help you.
The “Directory Access is Forbidden” message is from the Index.html page in that directory because you are trying to access it directly.
Claus's avatar
Claus
about 3 years ago
Hi Russ,
you wrote
> … the structure I use is to keep all of my own content seperate from the EE Directories …
I tried that, but EE 7 wouldn’t accept it. I had a separate directory /bilder/uploads/, but I had to delete it again because EE 7 didn’t accept it, like {base_url}/bilder/uploads/.
Claus
Russ K.'s avatar
Russ K.
about 3 years ago
I’m not sure what you mean by “EE wouldn’t accept it”. did you get an error in the control panel when you entered it that said it didn’t exist? If so, try again, but remove the backslash at the beginning.
Also, a couple things… just to be sure I’m understanding your setup… If you look in “Settings” -> URL and Path Settings. Does your {base_url} have a “/” at the end? for example: https://mysite.com/
IF it does…then make a couple changes to your URL….
First… replace “{base_url}. with “{site_url}” - I do not believe that base_url works on the front-end. and then remove the backslash directly after it… so your URL is “{site_url}images/uploads”.
Claus's avatar
Claus
about 3 years ago
> did you get an error in the control panel …
Yes. Besides that, I will make the modifications you suggested.
Claus
P. S.: I did as you suggested, but now the page is messed up. The style sheets are gone. I replaced {base_url} with {site_url} everywhere on the page. Maybe that was a mistake. :-( Is there a config file where I can fix those errors?
Russ K.'s avatar
Russ K.
about 3 years ago
OK…. just to be clear… in the Control Panel you use {base_url} or {base_path}. on the Site Front-end (in your html) you use {site_url}
R
Claus's avatar
Claus
about 3 years ago
Ok, thanks, I was able to fix it.
Claus
