Fix Directory access is forbidden Error
reinvent's avatar
reinvent
3 years ago
reinvent's avatar reinvent
1- I was setting-up upload directories from the CP > Files tab, then notice that the home page started to get this error:
‘Directory access is forbidden’ -on home page only.
Then I learned if I add the ‘index.php’ to my domain URL, the page loads.
http://shipbusters.com/index.php
2- I have learned now that EE v7 auto-created a directory structure resulting in duplicate directory names at the root (in this case named ‘assets’. I manually deleted from my FTP client, then I went into CP and deleted the associated upload directory in >Files Tab
3- Cleared Cache and tried to reload page via ‘http://shipbusters.com/’
Returned same error…
Any ideas on getting this working again?
Thanks for reading!
kindly, matt
3 years ago
Hi Matt,
It looks like if I add index.php back into your URL then the site is loading.
It looks like you’ll need to add a Apache Rewrite or similar for Nginx. After that it should resolve as desired.
-Tom Jaeger
reinvent's avatar
reinvent
3 years ago
Hey Tom,
Thanks for your reply.
I will try your recommendation.
…what would have caused this ‘change’ and suddenly throw this error after running smooth for weeks?
Kindly, matt
reinvent's avatar
reinvent
3 years ago
Update:
Did rewrite procedure and created .htaccess file ect.
Drops the ‘index.php’ on all pages and runs fine, but home page still throws the
Directory access is forbidden.
SteveCode's avatar
SteveCode
3 years ago
SteveCode's avatar SteveCode
I also has the same problem
reinvent's avatar
reinvent
3 years ago
Hey Steve,
Can you share a little about your issue?
Looks like I will have to buy support and escalate this problem and clues you may have might be helpful.
matt
reinvent's avatar
reinvent
3 years ago
The fix for my issue was the sys seemed to generate an index.html file in my root directory with “Directory access is forbidden.”
When I removed it, all works.
Thank Robin for her wisdom…took her no time to resolve 😉
m
? 1
