Dynamic recipient Freeform sending multiple times
VRDL's avatar
VRDL
3 years ago
VRDL's avatar VRDL
When using Freeform dynamic recipients. And some recipients share same e-mailaddress. Freeform will send multiple e-mails. So for example:
Label - E-mail Gary - [email protected] Fred - [email protected] Harry - [email protected] Anne - [email protected]
When Anne or Harry is choosen from the form, it will send 2 e-mails to both harry and anne, but i want to show the label in the notification so “Harry” and just send only one e-mail to [email protected].
Any clue someone?
Thanks in advance.
Wessel
Justin Alei's avatar
Justin Alei
3 years ago
Justin Alei's avatar Justin Alei
Unfortunately this has to do with how Freeform was built and they basically said it’s not going to be fixed. If the mail.com here happens to use Gmail they could use [email protected] and [email protected], but if not, there’s not much else you can do besides setup alias email accounts to keep that unique. I ran into this same thing and had to switch to use EE Harbor Forms, but that brought it’s own set of challenges.
Rob Allen's avatar
Rob Allen
3 years ago
Rob Allen's avatar Rob Allen
I ran into the same problem a while back.
My solution was to use alias email addresses for the duplicates in the recipients list and use server side forwarding to a single email box.
So in your case:
Gary - [email protected] Fred - [email protected] Harry - [email protected] (gets forwarded to [email protected]) Anne - [email protected] (gets forwarded to [email protected])
clara167's avatar
clara167
about 2 years ago
clara167's avatar clara167
The upkeep of a blog can provide an array of advantages. I found great delight in the process of reading this exceptionally informative text. capybara clicker
Alagko's avatar
Alagko
Alagko's avatar Alagko
L’originalité est donc primordiale : plagier ou reproduire des contenus déjà publiés peut nuire à votre réputation et diminuer la confiance que vos lecteurs vous accordent. Au lieu de cela, offrez des perspectives nouvelles, des recherches détaillées et des conseils pratiques que votre audience pourra appliquer dans leur quotidien. Write for us
