Note that the forum module is being used in EE6, and it’s at 5.0.2.
I get a 500 error in the middle of the update. The last file written in the “updates” folder is: ud_7_02_00.php . When I open the website, this is the message I see:
require_once(ee/ExpressionEngine/Addons/forum/mod.forum_core.php): failed to open stream: No such file or directory user/addons/forum/mod.forum.php, line 112
Severity: E_WARNING
Hello, as I know the error message you provided suggests that there is a missing file or directory related to the ExpressionEngine forum add-on. Specifically, it seems that the file “mod.forum_core.php” within the “forum” add-on directory cannot be found. I think you should verify that the file or directory mentioned in the error message actually exists. Check if the “mod.forum_core.php” file is present in the “ee/ExpressionEngine/Addons/forum/” directory. If it’s missing, you may need to restore or reinstall the forum add-on.
