Addon/Feature to display a file's associated entries
methodmedia's avatar
methodmedia
3 years ago
methodmedia's avatar methodmedia
Is there a feature or an addon to display the entries that are using a particular file? Like if I click an image file in a file directory I’m able to see which entries are using it and their links.
3 years ago
In version 7 there is a usage tab on the file details. Please note, if your upgrading from an older version, you won’t be able to see this until you Update File Usage (Tools-> Utilities-> Update File Usage).
Please see https://docs.expressionengine.com/latest//control-panel/file-manager/file-manager.html#compatibility-mode
-Tom Jaeger
