relate members to channels - Solved
Alessandro Proglio's avatar
Alessandro Proglio
3 years ago
Alessandro Proglio's avatar Alessandro Proglio
I need to relate somehow members to channels, (as an example to keep track of which entry relates to which user, an entry not necessary created by that user, in my case) but members custom fields are limited to few field types not including relationship, and vice versa there is no possibility to choose the users channel in the relationship field type. I suppose this is done by design. Do I have to build a user channel by myself and ignore the user management bundled with EE?
SOLVED: The extension GB Member Select does what I’m looking for. https://expressionengine.com/add-ons/gb-member-select
? 1
maymarilyn's avatar
maymarilyn
3 years ago
maymarilyn's avatar maymarilyn
samtaber's avatar
samtaber
3 years ago
samtaber's avatar samtaber
Thank you, that is exactly what I needed.
