How do I add more Roles to myself as a SuperAdmin?
yzs's avatar
yzs
3 years ago
yzs's avatar yzs
Hi! I cannot find the setting to add more roles for myself. I nees your help!
3 years ago
What’s the use case here? Assuming you’re a super admin, then you already have permissions for everything.
Cecil Walls's avatar
Cecil Walls
3 years ago
Cecil Walls's avatar Cecil Walls
If you’re a top-level administrator, you probably have access to everything.
William Wilkerson's avatar
William Wilkerson
3 years ago
William Wilkerson's avatar William Wilkerson
hi you heed admin
yzs's avatar
yzs
3 years ago
yzs's avatar yzs
I wanted to prototype a membership site using EE with Dummy Users
User Secondary Roles: Gold - Silver - Platinum
sonachandis's avatar
sonachandis
sonachandis's avatar sonachandis
As a SuperAdmin, you have the highest level of control over your system, including the ability to assign and manage roles. Follow these simple steps to add more roles to yourself:
Steps to Add Roles as SuperAdmin: Log in to your admin dashboard with SuperAdmin credentials. Navigate to User Management or Roles & Permissions settings. Locate your SuperAdmin profile. Click on Edit Roles or Assign Permissions (varies by platform). Select the new roles you wish to assign to yourself. Click Save Changes and refresh the page to apply updates. By doing this, you can expand your access to various administrative functionalities.
For more insights, visit: Sona Chandis
