I’ve been informed by a client that their site has slowed down massively since the EE7 upgrade. I’ve have the PRO licence.
I’ve enabled debugging, overview of homepage below.
75.9MB Templates 126 Queries 13.9967s Load
Below is the output of the template tab.
Could this be looked into and advise what can be done to reduce the load time.
Templates
0.000009 / 3.2MB - Begin Template Processing -
0.000016 / 3.2MB URI:
0.000018 / 3.2MB Template: /
0.000023 / 3.2MB Retrieving Template from Database: /index
0.000391 / 3.2MB Retrieving Template from File
0.000901 / 3.3MB Template Type: webpage
0.000907 / 3.3MB Parsing Site Variables
0.002793 / 3.3MB Config Assignments & Template Partials
0.002984 / 3.3MB Parse Current Time Variables
0.003019 / 3.3MB Parsing Segment, Embed, Layout, logged_in_*, and Global Vars Conditionals
0.006509 / 3.4MB - Beginning Tag Processing -
0.006514 / 3.4MB Detecting Tags in Template
0.006539 / 3.4MB No Closing Tag
0.006655 / 3.4MB Running Tags
0.006909 / 3.4MB Calling Tag: {exp:seo_lite default_title="A global creative production and events agency | World Wide Group" default_description="World Wide Group, harnessing over 85 years’ experience telling those stories, we deliver worldwide events for global brands, charities and governments."}
0.007356 / 3.4MB -> Data Returned
0.007711 / 3.5MB Calling Tag: {exp:channel:entries channel="sector" fixed_order="2|3|4" disable="categories|member_data|pagination"}
0.028565 / 4.5MB Replace all of the relationship fields
0.971695 / 9.6MB Replace all of the relationship fields
1.444340 / 12.0MB Replace all of the relationship fields
1.926534 / 13.6MB -> Data Returned
1.926715 / 13.6MB Calling Tag: {exp:channel:entries channel="work" limit="3" disable="categories|member_data|pagination"}
2.406165 / 16.3MB Replace all of the relationship fields
2.878529 / 18.7MB Replace all of the relationship fields
3.350906 / 21.1MB Replace all of the relationship fields
3.355371 / 21.0MB -> Data Returned
3.355551 / 21.0MB Calling Tag: {exp:channel:entries channel="client" url_title="clients" disable="categories|member_data|pagination"}
10.958146 / 60.0MB Replace all of the relationship fields
10.971292 / 60.0MB -> Data Returned
10.971507 / 60.0MB Calling Tag: {exp:channel:entries channel="team" limit="3" disable="categories|member_data|pagination"}
10.977830 / 60.3MB Replace all of the relationship fields
11.450605 / 62.7MB Replace all of the relationship fields
11.925848 / 65.2MB Replace all of the relationship fields
12.414927 / 67.5MB -> Data Returned
12.415137 / 67.5MB Calling Tag: {exp:channel:entries channel="blog" limit="3" disable="categories|member_data|pagination"}
12.902592 / 70.2MB Replace all of the relationship fields
13.385550 / 72.6MB Replace all of the relationship fields
13.869809 / 75.1MB Replace all of the relationship fields
13.885136 / 74.9MB -> Data Returned
13.885161 / 74.9MB - End Tag Processing -
13.885202 / 74.9MB Processing Layout Templates
13.885291 / 75.0MB Retrieving Template from Database: wwg/_default_layout
13.885944 / 75.0MB Retrieving Template from File
13.886240 / 75.0MB Template Type: webpage
13.886260 / 75.0MB Parsing Site Variables
13.886308 / 75.0MB Config Assignments & Template Partials
13.886565 / 75.0MB layout Variables: (show more)
13.886703 / 75.0MB Parse Current Time Variables
13.886888 / 75.0MB Parsing Segment, Embed, Layout, logged_in_*, and Global Vars Conditionals
13.891410 / 75.1MB - Beginning Tag Processing -
13.891416 / 75.1MB Detecting Tags in Template
13.891500 / 75.1MB Running Tags
13.892042 / 75.1MB Calling Tag: {exp:freeform_next:form form="contact" submit_class="btn btn-celadon mt-3" return_url="/" class="" }
13.906594 / 75.4MB Calling Extension Class/Method: Freeform_next_ext/addHoneypotInputToForm
13.915469 / 75.6MB Calling Extension Class/Method: Freeform_next_ext/addHoneypotJavascriptToForm
13.915588 / 75.6MB Calling Extension Class/Method: Freeform_next_ext/addDateTimeJavascript
13.915698 / 75.6MB Calling Extension Class/Method: Freeform_next_ext/addFormDisabledJavascript
13.915909 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addFormAnchorJavascript
13.916021 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addTableJavascript
13.916033 / 75.6MB -> Data Returned
13.916141 / 75.7MB Calling Tag: {exp:freeform_next:form form="newsletter" return_url="/" }
13.918747 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addHoneypotInputToForm
13.920178 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addHoneypotJavascriptToForm
13.920293 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addDateTimeJavascript
13.920402 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addFormDisabledJavascript
13.920575 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addFormAnchorJavascript
13.920712 / 75.7MB Calling Extension Class/Method: Freeform_next_ext/addTableJavascript
13.920723 / 75.7MB -> Data Returned
13.920737 / 75.7MB - End Tag Processing -
13.920742 / 75.7MB Processing Advanced Conditionals
13.921558 / 75.7MB - End Template Processing -
13.921561 / 75.7MB Parse Global Variables
13.935913 / 75.9MB Template Parsing FinishedThanks! I’m on the latest, so it must not be that specific bug. I’ll keep digging.
