How to install an add-on in expression engine?
semeria1999's avatar
semeria1999
3 years ago
semeria1999's avatar semeria1999
Hello good day, I already tried to install an add-on from the /system/user/addons directory, but it does not recognize it, how can I install it, are permissions required?
Yuri's avatar
Yuri
3 years ago
Yuri's avatar Yuri
If you are not superadmin, you need to have permission “Install or remove add-ons”
Otherwise, make sure the add-on supports your ExpressionEngine version and the folder structure is correct (there need to be a single folder that contains main add-on file and the folder name should match the add-on name)
? 2
William Wilkerson's avatar
William Wilkerson
3 years ago
William Wilkerson's avatar William Wilkerson
thanks
elenangry's avatar
elenangry
elenangry's avatar elenangry
Unzip the add-on’s contents after downloading it. The add-on’s folder should be uploaded to your system/user/addons folder. Once the add-on has been uploaded, you should be able to find it in the ExpressionEngine Control Panel’s Add-on Manager. After that, click install! Play kick the buddy.
