Download Content Add-On
verve's avatar
verve
3 years ago
verve's avatar verve
I found this tutorial and wonder if it is also possible to use it to export a file with all the entries from the channel. If so, how would I have to do that? Link: Downloadable iCalendar Files
Russ K.'s avatar
Russ K.
3 years ago
Russ K.'s avatar Russ K.
Yeah, you can definitely do this.
You just need to set up the appropriate {exp:channel:entries} tag and then manually configure the output in whatever format you need (xml, json, csv, etc).
There are also Addons from Zealous Labs like SmartExport, or Smart Import/Export that streamline this.
R
verve's avatar
verve
3 years ago
Thanks for the help. How can I modify the example (.ical file - see link in first post) so that I can offer ALL channel entries in one file for download and the user can import them into his calendar?
