Search only working if entry is saved again
captainahab's avatar
captainahab
3 years ago
captainahab's avatar captainahab
Some fields in some entries do not appear in search results. Rebuilding the search index makes no difference. This can be bloq fields or ee text inputs, textareas … if I change some whitespace e.g. and save it, the search result is updated. Open every entry with 400+ is not really an option – is there a way to update all entries without clicking every single one?
3 years ago
Hi Captainahab,
What version of ExpressionEngine and PHP are you running?
-Tom Jaeger
captainahab
3 years ago
7.4.30
3 years ago
Is it safe to assume this is in EE 6 or 7 as well?
captainahab
3 years ago
yes, 6.x
