How to get a custom field's value in PHP for a specific entry?
Felix Edward Todd's avatar
Felix Edward Todd
3 years ago
Felix Edward Todd's avatar Felix Edward Todd
Let’s say I have an entry with ID “123” and I need to get the value of a custom field with shortname “custom_field.”
In ExpressionEngine, I know I can use the {exp:channel:entries} tag, but I need to do it via PHP.
USC Chan's avatar
USC Chan
3 years ago
USC Chan's avatar USC Chan
You can use the ChannelEntry model pretty easily for this:
$entry_id = 123;
$entry_object = ee('Model')
                ->get('ChannelEntry')
                ->filter('entry_id', $entry_id)
                ->first();
$field_data = $entry_object -> field_id_5;
where the custom field you’re looking for in this case has an ID of #5. These examples taken from https://docs.expressionengine.com/latest/development/models/channel-entry.html
? 1
Felix Edward Todd
3 years ago
Thank you very much!
Jemis's avatar
Jemis
Jemis's avatar Jemis
I also cannot solve this problems until I read your post. It is so beneficial. Luv all. geometry dash scratch
