Fresh install with errors
News and General
andriusb's avatar
andriusb
3 years ago
andriusb's avatar andriusb
Hi there.
Installed latest EE, but then navigating in admin area and pressing Files, I get this error:
LogicException Caught
The root path /tmp is not readable.
ee/ExpressionEngine/Library/Filesystem/Adapter/Local.php:47
Stack Trace: Please include when reporting this error
#0 ee/legacy/libraries/Filemanager.php(244): ExpressionEngine\Library\Filesystem\Adapter\Local->__construct()
#1 ee/legacy/libraries/Filemanager.php(1184): Filemanager->get_image_dimensions()
#2 ee/ExpressionEngine/Service/Thumbnail/ThumbnailFactory.php(53): Filemanager->create_thumb()
#3 ee/ExpressionEngine/Service/Thumbnail/ThumbnailFactory.php(31): ExpressionEngine\Service\Thumbnail\ThumbnailFactory->make()
#4 ee/ExpressionEngine/Library/CP/FileManager/Columns/Thumbnail.php(36): ExpressionEngine\Service\Thumbnail\ThumbnailFactory->get()
#5 ee/ExpressionEngine/Library/CP/EntryManager/ColumnRenderer.php(58): ExpressionEngine\Library\CP\FileManager\Columns\Thumbnail->renderTableCell()
#6 [internal function]: ExpressionEngine\Library\CP\EntryManager\ColumnRenderer->ExpressionEngine\Library\CP\EntryManager\{closure}()
#7 ee/ExpressionEngine/Library/CP/EntryManager/ColumnRenderer.php(59): array_map()
#8 ee/ExpressionEngine/Library/CP/FileManager/Traits/FileManagerTrait.php(349): ExpressionEngine\Library\CP\EntryManager\ColumnRenderer->getRenderedTableRowForEntry()
#9 ee/ExpressionEngine/Controller/Files/Files.php(34): ExpressionEngine\Controller\Files\AbstractFiles->listingsPage()
#10 [internal function]: ExpressionEngine\Controller\Files\Files->index()
#11 ee/ExpressionEngine/Core/Core.php(268): call_user_func_array()
#12 ee/ExpressionEngine/Core/Core.php(124): ExpressionEngine\Core\Core->runController()
#13 ee/ExpressionEngine/Boot/boot.php(184): ExpressionEngine\Core\Core->run()
#14 admin.php(139): require_once('...')
Then I made tmp folder in root path (next to images, system, themes), but it didn’t help.
Bryan's avatar
Bryan
3 years ago
Bryan's avatar Bryan
This looks like a similar issue to https://github.com/ExpressionEngine/ExpressionEngine/issues/2303. Could you share some details about the hosting environment you’re running this on?
Operating System:
PHP version:
SYSPATH: (path to /system folder)
FCPATH (path to index.php/admin.php)
Hosting type: (Dedicated, Shared, VPS, Local)
You can replace any sensitive info in the paths with *** but this will help us reproduce the issue and get a fix out
