Removing Previous Role when using Simple Commerce
funnEE's avatar
funnEE
3 years ago
funnEE's avatar funnEE
When a user purchases a role using simple commerce, that new role is added to an array of roles the user has. Unfortunately, I want the user’s previous role to be removed when using simple commerce. How can I make this happen, even if I need to add code to a template?
So far, this is all I can find in the Member Model. Thanks
Emmal21's avatar
Emmal21
Emmal21's avatar Emmal21
Sometime, the model might occurs some problems. You can try in next time. I recommend trap the cat to you. Why don’t you try joining it?
