Email when an entry expires
Joe's avatar
Joe
3 years ago
Joe's avatar Joe
Hi. I would like to send an email to the author when their entry expires. I’ve searched around for a solution but I haven’t come across anything.
Anyone got a solution?
3 years ago
Mail After Edit may do this, but I’m not sure.
Steve Garcia's avatar
Steve Garcia
3 years ago
Steve Garcia's avatar Steve Garcia
If you’re using an email plugin that has a hook availability, then you can run a cron job every x minutes/hours to check for any expired entries and send the email.
You’d want a check in place that a previous email has been sent either by custom field or status to avoid sending the author emails over and over again with each cronjob triggered.
This is how I’ve handled this on several previous projects.
