PDOException: EE Wizard
Katy's avatar
Katy
3 years ago
Katy's avatar Katy
Hi all - I’m a long time EE user (still running 2.x on two different blogs) and I wanted to create a new test blog in v6 in preparation for upgrades.
When I run the EE wizard, I get a PDO error:
Fatal error: Uncaught exception ‘PDOException’ with message ‘SQLSTATE[28000] [1045] Access denied for user ‘[user]’@’localhost’ (using password: NO)’ in /home/[path]/[domain]/ee_wizard/index.php:254 Stack trace: #0 /home/[path]/[domain]/ee_wizard/index.php(254): PDO->__construct(‘mysql:host=loca…’, ‘[user], ”, Array) #1 /home/[path]/[domain]/ee_wizard/index.php(131): check_db(Array) #2 {main} thrown in /home/[path]/[domain]/ee_wizard/index.php on line 254
I’ve created and recreated the database and user and nothing is working. I’m sure I’m missing something obvious… any suggestions?
3 years ago
Katy, does your database user not have a password? The only time I can replicate the error you’re seeing is when I run the server wizard and leave the password field blank. If this is consistently happening, try debugging by creating a user with a password and testing with that user and password.
Versachi's avatar
Versachi
Versachi's avatar Versachi
The error is the analysis data. You need to change the dot and code. I will give you some samples later. spacebar clicker
