Reorganize a channel's field order
freaksarise's avatar
freaksarise
3 years ago
freaksarise's avatar freaksarise
Years ago I can recall being able to click something and then was able to drag and drop fields to reorganize, resize, and lay them out in various formats. Is that still possible with the current version? Thanks!
freaksarise
3 years ago
I found it! Once on the channel tab, there is an option for LAYOUTS within that channel’s settings. I am good. I’ll leave this hear in the event others need it in the future. Thanks
? 3
abel1303's avatar
abel1303
3 years ago
abel1303's avatar abel1303
If you have a channel that consists of a mix of videos and articles, you may want to consider reorganizing its field order. This will help make it easier to find the video you’re looking for, and it will also help to organize the content more effectively
Soltero's avatar
Soltero
Soltero's avatar Soltero
It still works: click something and then was able to drag and drop fields to reorganize, resize, and lay them out in various formats. Papa’s Pizzeria
