Shortcut to Structure
freaksarise's avatar
freaksarise
3 years ago
freaksarise's avatar freaksarise
I know this question seems trivial but many years back, I was able to place shortcuts in the control panel’s primary nav bar. One for example would be to shoot directly to Structure vs having to click addons, then choose structure. I did update the prefs to navigate to structure on login, but am still curious how to place my own shortcuts within the CP nav? Thanks!
freaksarise
3 years ago
I believe I may have reminded myself where it is located. I was confusing myself with the CP nav bar and the channel’s layout’s tabs. I now see the TABS section and this is most likely what I was recalling. The UI has changed since my last time working in EE. Thank you
Krein's avatar
Krein
Krein's avatar Krein
You can learn more in the gg. Then, there are a lot of beneficial information for you. You can join it to know more. Have a nice day. What do you know geometry dash 23? It is one of the best game of Geometry Dash series.
dryfirewood's avatar
dryfirewood
dryfirewood's avatar dryfirewood
Friday Night Funkinis the best music game I’ve ever played!
Joshua Hughes's avatar
Joshua Hughes
Joshua Hughes's avatar Joshua Hughes
Is PayMeToDoYourHomework legit? Absolutely! I’ve used their service multiple times for urgent assignments. They deliver quality work promptly, and their customer service is top-notch. If you’re looking for reliable academic assistance, I highly recommend them.
