How can I separate two websites that are made with MSN?
verve's avatar
verve
about 4 years ago
verve's avatar verve
What ist the best way to seperate? I am on EE 5.4.3 and want to find a way how to separate the database. I know how to sperate the files, export channels, setting up a new installation and export/import the entries etc. But is there another and faster way to do this? Thanks
about 4 years ago
Unfortunately, there really is not. Doing it manually is the best way to make sure everything transfers over as expected.
janiceadeltoro's avatar
janiceadeltoro
janiceadeltoro's avatar janiceadeltoro
The process of separating two websites made with MSN involves identifying the components or elements that need to be separated, creating a backup, determining the hosting environment, and updating any internal links or references. It is recommended to consult with a web developer or IT professional if not familiar with the technical aspects of the separation process. TheWebFactory provides custom web design and digital marketing strategies to increase online visibility and attract potential clients.
DracoDeans's avatar
DracoDeans
DracoDeans's avatar DracoDeans
Hi, to separate a database in EE 5.4.3, there are several methods like exporting channels, setting up a new installation, and exporting/importing the entries. However, if you are looking for a faster way to do this, there might be other methods available. Unfortunately, I couldn’t find any specific details on faster methods.
