Best way to parse REST/JSON for use in template!
captainahab's avatar
captainahab
3 years ago
captainahab's avatar captainahab
I need to consume some data via REST and render it in a template, there seem to be no plugins or any other ee solution. Any recommendations? Thanks!
vw000's avatar
vw000
3 years ago
vw000's avatar vw000
I’m not sure about a plugin because every API is different. Either way, if you get results in JSON this should be quite simple, no plugin required. You would just use the same code you normally inside your template.
A template can be JavaScript, or you can turn on PHP and use PHP to interact with the API. Or you can even just create a normal HTML post form that interacts with the requests.
It’s your choice. In case of REST, you can use any code that does standard http requests. You should first analyze how you want to manipulate or use the data to be able to see the best approach.
marcusramirez's avatar
marcusramirez
marcusramirez's avatar marcusramirez
If you need more advanced templating capabilities, consider using a templating library like Handlebars.js or slope game.
