update from 6.0 to 6.2 fails
NathanPOMO's avatar
NathanPOMO
NathanPOMO's avatar NathanPOMO
when selecting upgrade now in the control panel it downloads the update and starts applying it, then stops, leaving this stack trace
0 ee/legacy/database/drivers/mysqli/mysqli_driver.php(112): CI_DB_mysqli_connection->query('SELECT CookieSe...')
1 ee/legacy/database/DB_driver.php(260): CI_DB_mysqli_driver->_execute('SELECT CookieSe...')
2 ee/legacy/database/DB_driver.php(175): CI_DB_driver->simple_query('SELECT CookieSe...')
3 ee/legacy/database/DB_active_rec.php(1076): CI_DB_driver->query('SELECT CookieSe...')
4 ee/ExpressionEngine/Service/Model/Query/Select.php(51): CI_DB_active_record->get()
5 ee/ExpressionEngine/Service/Model/DataStore.php(275): ExpressionEngine\Service\Model\Query\Select->run()
6 ee/ExpressionEngine/Service/Model/DataStore.php(220): ExpressionEngine\Service\Model\DataStore->runQuery('Select', Object(ExpressionEngine\Service\Model\Query\Builder))
7 ee/ExpressionEngine/Service/Model/Query/Builder.php(138): ExpressionEngine\Service\Model\DataStore->selectQuery(Object(ExpressionEngine\Service\Model\Query\Builder))
8 ee/ExpressionEngine/Service/Model/Query/Builder.php(63): ExpressionEngine\Service\Model\Query\Builder->fetch()
9 ee/ExpressionEngine/Core/Provider.php(368): ExpressionEngine\Service\Model\Query\Builder->all()
10 ee/legacy/libraries/Core.php(133): ExpressionEngine\Core\Provider->registerCookiesSettings()
11 ee/legacy/core/Controller.php(65): EE_Core->bootstrap()
12 ee/legacy/core/Controller.php(76): Base_Controller->__construct()
13 ee/ExpressionEngine/Core/Core.php(246): EE_Controller->__construct()
14 ee/ExpressionEngine/Core/Core.php(113): ExpressionEngine\Core\Core->runController(Array)
15 ee/ExpressionEngine/Boot/boot.php(161): ExpressionEngine\Core\Core->run(Object(ExpressionEngine\Core\Request))
16 index.php(164): require_once('...')
17 {main}
it lets us roll back just fine so not in a big rush to fix, but would appreciate any help
Nathan, do you have any sort of caching turned on? I think we’ve seen similar instances before when memcache was clutching on to the past. If so try clearing all caches and run the upgrade again.
The advice to clear cache is good. I’d also check and be sure you don’t have:
> 5. route requests to the installer app instead of the main app by changing EE_INSTALL_MODE to TRUE in .env.php. You can change this back when you’re done.
Set anywhere. I can somewhat imagine that being a problem. Basically- if you have an .env.php in there, I’d likely just rename it when you try again.
