How do I find an auto-saved channel entry?
Brooke's avatar
Brooke
Brooke's avatar Brooke
One of our producers was creating an entry and got kicked out of the system because here credentials expired. She did notice that the entry was auto-saved as shown by the yellow label. But we can’t find the entry anywhere? Is there any particular place where you can view auto-saved entries?
Thanks, Brooke
Brooke. If you’re editing an entry that has revisions turned on, you can find the saved entry in the “Revisions” tab.
If it’s a new entry that never got saved, then you can go back to that channel and click on New to create a new entry. There should now be a tab for “Auto Saves” from where you can view the autosave entry and save it if you wish.
charlymox's avatar
charlymox
3 years ago
charlymox's avatar charlymox
Thank you, I faced the same situation when I was working on my project https://studyessay.org/.Found an autosaved copy in the Revisions section
