RSS Parser
vw000's avatar
vw000
vw000's avatar vw000
Does someone know if Twitter still supports RSS for its tweets? If yes, could the EE RSS Parser be used to get those feed and properly format them?
I don’t think Twitter directly provides anything, but there are a handful of services out there that can generate a feed from Twitter for you (try rss.app. The EE RSS Parser shouldn’t have any trouble parsing the feed once you have it generated.
Other options of interest or for those who might find this post later on:
  • The Twitter API is pretty straightforward as well, if you want to build something yourself. There are plenty of tutorials and PHP libraries out there to get you started with this. This method will also give you the most control over everything you’re consuming and displaying.
  • Hop Social Suite is a great add-on to allow you to consume a social feed and display how you want on your site.
vw000's avatar
vw000
I do remember that some years back Twitter actually did provided RSS feeds directly. Not sure why they removed that option.
My question is more about the RSS parser on EE. Assuming I turn a tweet or anything else into an RSS I could be able to format that content directly on a template page correctly using this addon?
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
Yes you can create an RSS feed and display using the RSS Parser plugin. Your feed can contain any entries you want.
I do just this for a company that has their main site and a bunch of EE powered micro sites. I use an RSS feed to push out things like news and testimonials to the micro sites, so they publish once on the main site, then items such as filtered news headlines and pulled into each micro site as required.
Addendum: I actually use several feeds for various purposes.
? 1
vw000's avatar
vw000
Thanks, Rob, that is more or less what I also want to do. I want to get the same news headlines to a second site to avoid having to republish the same content.
