Upgrading Versions
Jake's avatar
Jake
Jake's avatar Jake
I just took over a website that is still on version 1.6.8. I need to upgrade to current version 6.1.6, Any tips would be greatly appreciated.
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
Welcome to the forums!
The biggest hurdle is replacing 3rd party addons - from memory relatively few have upgrades all the way, it depends what the site uses. Others may require extensive workarounds (the “Gypsy” field type for EE1 springs to mind).
So the first step is to find out what 3rd party addons the site uses then either:
  1. Upgrade where available, most addons will have separate versions to match the EE version so you’d need to plan upgrading in stages
  2. Find alternatives, will require template changes, you may have to swap to a different addon to do the dame thing or use native functionality that came after EE1
  3. Replace need for an addon with native functionality, features added to later versions of EE negate the need for several addons
There’s always the option to do a full rebuild so you can take advantages of the many new features that EE6 brings, you should be able to import most existing content using a data import addon, plus it gives you a chance to dump the old bits and start afresh. Sometimes a rebuild is a whole lot less hassle than an big upgrade.
vw000's avatar
vw000
vw000's avatar vw000
As Rob said, your biggest issue will be finding compatible add-ons if the site relies on them since most old add-ons don’t work anymore. Even official ones don’t work anymore, example, the Wiki module does not work on the latest EE 6 release. Not yet at least.
That version 1 is so old you will probably have to rewrite most of the code but is not only true for EE but any CMS, if you did not upgrade for years, you will in most cases just rebuild things to the new software using the same content.
