Image Manipulation Not working
bbailey's avatar
bbailey
bbailey's avatar bbailey
I have a bunch of image manipulations declared for each upload directory but none of them seem to be working. I want my uploaded images to be a certain size depending on where they are being displayed. Attached is an example the setup I have.
Note: I have tried the constrain and the crop and neither seem to be working. I’m not sure what I am doing wrong.
code Example within the Exp loop:
_ {mission_images}{mission_images:mission_image:listing}{/mission_images}_
An Image displays but it is the original image not the image manipulated one that should be created on upload.
benoitlemay's avatar
benoitlemay
benoitlemay's avatar benoitlemay
Hi there, Are yo using the File fieldtype or File Grid?..
If your field name (File filedtype) is {mission_images} did you try {mission_images:listing} ?.. (single tag and not inside the {mission_images}{/mission_images}?.
Please provide more details on your fieldtype type..
bbailey's avatar
bbailey
I am using a regular Grid Fieldtype. My field name is mission_images. Can I only use image manipulations in file/file grid types?
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
I’m assuming:
mission_images is the name of your grid field
mission_image is the file field inside the grid
{mission_images}
  {mission_images:mission_image}
    < img src="{url:listing}" width="{width:listing}" height="{height:listing}" alt="{title}" >
  {/mission_images:mission_image}
{/mission_Images}
? 1
bbailey's avatar
bbailey
Rob, thank you that works perfectly!
? 1
