CPanel question
RaVlaNa's avatar
RaVlaNa
RaVlaNa's avatar RaVlaNa
Hello, I am new here and I am also a new EE user. First of all, a very Happy New Year to everyone.
I would like to ask why my CPanel looks like in the attached file, while, when I see a Youtube film or something, the CPanel looks much more easier to use and totally different. Is there any way I can change this?
Thank you in advance.
? 1
Russ K.'s avatar
Russ K.
Russ K.'s avatar Russ K.
Hi there… Welcome to EE. The Control Panel you posted is EE version 6.x. Probably the others you have seen are versions 3 - 5, or even earlier.
? 1
RaVlaNa's avatar
RaVlaNa
OK, thank you. That wasn’t mentioned. The film said it was a starter for EE 6. Nevertheless. mystery solved. Thanks.
silenz's avatar
silenz
silenz's avatar silenz
And you are using an incomplete/outdated set of language files as it seems.
RaVlaNa's avatar
RaVlaNa
OK,I went to github, and that seemed to be the only one (Dutch) that was there. Any further advice possible, please?
