Index.php rewrite on Ubuntu
ottercreate's avatar
ottercreate
ottercreate's avatar ottercreate
Has anyone had issues getting the mod_rewrite to work through .htaccess file when site is hosted on Ubuntu 20.04? I cannot get this to work.
Do you have RewriteEngine on set in your virtual host?
ottercreate
Hi Andy,
Thank you for your speedy response. Would that be set in the 000-default file? (/etc/apache2/sites-available/000-default.conf)
I can’t answer for your specific server, but you should be looking for the .conf file that matches your site’s url and doc root in the ServerName and DocumentRoot directives.
ottercreate
I am not sure I understand the specific line we need in that .conf file and where to put it. Currently at the end, we have this:
<Directory /var/www/html>
     Options Indexes FollowSymLinks
     AllowOverride All
     Require all granted
</Directory>
Is there an additional line of code to be added here?
Looks like to enable to module you actually just need to run sudo a2enmod rewrite (sorry, it’s been a while since I’ve managed an Apache server). I’d suggest that you review this article and start at “Section 1—How to Activate Mod_Rewrites” https://www.digitalocean.com/community/tutorials/how-to-set-up-mod_rewrite#Section%201
ottercreate
We had already found that article and ran that code. Got the response that it was already enabled.
ottercreate
Is there a different version of code that should go in .htaccess for this environment?
(though even a simple code test for a redirect did not appear to function correctly either)
can you post your current htaccess file (or a redacted version)?
ottercreate
<IfModule mod_rewrite.c>
    RewriteEngine On
    RewriteBase /
    # Removes index.php from ExpressionEngine URLs
    RewriteCond %{THE_REQUEST} ^GET.*index\.php [NC]
    RewriteCond %{REQUEST_URI} !/=======/.* [NC]
    RewriteRule (.*?)index\.php/*(.*) /$1$2 [R=301,NE,L]
    # Directs all EE web requests through the site index file
</IfModule>
awesome. I’ve got to head out for the night, but I spin up an apache server tomorrow and test.
ottercreate
Our engineer just figured out what was wrong. We had to add that virtual server info (the <Directory…> code) to the SSL config too.
ah. that makes sense. glad you figured it out.
