Publish at a future data and time?
Les Bleus's avatar
Les Bleus
Les Bleus's avatar Les Bleus
Hello,
I’m new to the Expression Engine and I have a question about publishing. Is there a way to publish a channel entry at a set date and time in the future?
In the Date tab and I see the entry date. Can I set this to a future date and time? I tried that but don’t see the change.
Any suggestions or pointers?
Best Regards MC
jelle's avatar
jelle
jelle's avatar jelle
Yes you can use the date tab to set a publish date at a set date and time! the reason you don’t see your stuff is because it isn’t published yet. 😉 there are ways aroud this but currrently don’t have the time to go into that
Les Bleus's avatar
Les Bleus
I did that and saved it as a draft (saving as published is making changes LIVE immediately). But, I don’t see them LIVE at that time. Does this future need a special license? What are my debug options?
jelle's avatar
jelle
That probably means that you’ll have to go into the templates and find the exp:channel:entries tags that are showing this content They probably look like this: {exp:channel:entries channel="XXX" … show_future_entries="yes"} If you change that to show_future_entries=”no” you should be fine
