6.1.0 script tag is being replaced with [removed]
wgarczynski's avatar
wgarczynski
wgarczynski's avatar wgarczynski
On 6.0.6 it was possible to add script tag inside channel entry. After 6.1.0 script tags are replaced with [removed]. I can’t find any setting to turn this feature off. How I can prevent this from happening? It breaks all struturized data on whole website.
Yuri's avatar
Yuri
Yuri's avatar Yuri
This is likely same issue that is reported in https://expressionengine.com/forums/topic/253226/6.1.0-breaks-iframe-tags-in-textarea-with-formatting-set-to-none We are working on fix and will be releasing ASAP
wgarczynski
Yuri's avatar
Yuri
Yuri's avatar Yuri
EE 6.1.1 has just been released that fixes this issue
? 2
