Plugin not showing in Add-On Manager
DXC's avatar
DXC
DXC's avatar DXC
Hello,
I followed this documentation to create a plugin, but it is not showing up in the Add-On Manager. I have tested this on multiple installations of EE v6 and it’s the same story every time. I suspect that the documentation is flawed, but I am too new to EE to be able to make such bold claims.
Can someone try following this tutorial to see where the issue might be? Any help is greatly appreciated!
—DXC
DXC's avatar
DXC
DXC's avatar DXC
I was able to find the issue and it is with the documentation. This tutorial from Zealous worked, and after digging through the GitHub commits I know why… It has to do with the folder naming conventions and also the ‘namespace’ key in the addon.setup. The documentation had this previously, but it was removed.
Hope others with this issue find this as a solution.
