Unable to locate the model you have specified: rte_toolset_model
jbrookechao's avatar
jbrookechao
jbrookechao's avatar jbrookechao
I updated my site to ExpressionEngine 6.06 a while back, and I’m running into a problem where I frequently get the following error when trying to edit or delete entries:
“Unable to locate the model you have specified: rte_toolset_model”
And of course, when I go back or even close the window and re-open the entry, the changes I made are not there.
I have verified that the Rich Text Editor add-on is present and installed, and even have uninstalled it and reinstalled it, but the problem persists. Can anyone tell me what is causing this and how to fix it?
When I’ve done a search on the error, I see a couple of posts from years back referencing a “models” folder that doesn’t exist for that addon in EE 6. Adding it from a download of a previous version caused more errors, so I removed it again.
jbrookechao
I figured it out, for those who may run into this…Rich Text Editor is depricated in EE 6.0 and above. So when I updated it didn’t remove the addon. I finally tried just uninstalling it, and that solved the issue.
Adam Khan's avatar
Adam Khan
3 years ago
Adam Khan's avatar Adam Khan
Excellent, thanks for this!
