Output articles with <p> tags?
scottb's avatar
scottb
scottb's avatar scottb
A vendor has asked me if it’s possible to output articles with paragraph tags rather than auto line breaks. Is that possible?
strudel's avatar
strudel
strudel's avatar strudel
Not sure what version of EE you’re using or what sort of text field you’re using for the articles, but some of them output with “ already. If you’re using a regular text area, go to the field and under Text Formatting and select XHTML. Maybe that’s what you’re looking for?
? 1
scottb's avatar
scottb
After so many years with EE, I have learned something new. Thanks for the tip.
? 1
vw000's avatar
vw000
vw000's avatar vw000
Sure, you can even output HTML code if you want. It depends on how you have set up your text form field and the settings in the channel.
