Changing paths in database
labtjd's avatar
labtjd
labtjd's avatar labtjd
Upload paths for images, etc seem to be in the database. So, in moving to a new server it seems not to update those paths, and if I go to the image upload editor to change them, I get:
SQLSTATE[42S22]: Column not found: 1054 Unknown column ‘0’ in ‘where clause’: SELECT group_id, group_name, sort_order FROM (exp_category_groups) WHERE site_id = 1 AND (exclude_group = “0” OR exclude_group = “1”) ORDER BY group_name ee/legacy/database/drivers/mysqli/mysqli_connection.php:117
Stack Trace: Please include when reporting this error
0 ee/legacy/database/drivers/mysqli/mysqli_driver.php(112): CI_DB_mysqli_connection->query(‘SELECT `group_i…’)
1 ee/legacy/database/DB_driver.php(270): CI_DB_mysqli_driver->_execute(‘SELECT `group_i…’)
2 ee/legacy/database/DB_driver.php(180): CI_DB_driver->simple_query(‘SELECT `group_i…’)
3 ee/legacy/database/DB_active_rec.php(1138): CI_DB_driver->query(‘SELECT `group_i…’)
4 ee/legacy/models/category_model.php(100): CI_DB_active_record->get()
5 ee/EllisLab/ExpressionEngine/Controller/Files/Uploads.php(312): Category_model->get_category_groups(”, false, 1)
6 ee/EllisLab/ExpressionEngine/Controller/Files/Uploads.php(49): EllisLab\ExpressionEngine\Controller\Files\Uploads->form()
7 [internal function]: EllisLab\ExpressionEngine\Controller\Files\Uploads->create()
8 ee/EllisLab/ExpressionEngine/Core/Core.php(241): call_user_func_array(Array, Array)
9 ee/EllisLab/ExpressionEngine/Core/Core.php(110): EllisLab\ExpressionEngine\Core\Core->runController(Array)
10 ee/EllisLab/ExpressionEngine/Boot/boot.php(151): EllisLab\ExpressionEngine\Core\Core->run(Object(EllisLab\ExpressionEngine\Core\Request))
11 index.php(148): require_once(‘…’)
I am on 5.3.2 PHP 7.2.24 Centos 8
Brian Litzinger's avatar
Brian Litzinger
You can skip the database all together when defining upload paths: https://docs.expressionengine.com/latest/general/system-configuration-overrides.html#upload_preferences
Define them in your config, then you don’t need to worry about editing them in the control panel.
labtjd's avatar
labtjd
Thanks, do you think that setting the proper path would also clear that php error?
labtjd's avatar
labtjd
Okay, yes, it is possible to override in the configuration files, but my fundamental issue was incorrect sql being submitted. I noticed that the query would run if I just had single quotes on the ‘0’. So, there is a mysql setting that allows double quotes to act as single quotes. Which is something about ansi_quotes sql mode.
So change the mode on your mysql server
