EE 6 Comment Total
gunnersmaj's avatar
gunnersmaj
gunnersmaj's avatar gunnersmaj
I was wondering if you guys can help.
Basically, I have a page that has comments at the bottom. What I am trying to set up, is that at the top of the page it shows how many comments have been made in total.
The issues I am running into here is trying to get the number to show no matter the tags I use: - {total_comments} - {total_results} - {absolute_results}
In order to get the values to show up, I have to contain them within the {exp:comment:entries} tag. But in doing so it repeatedly repeats the number of comments. For example, if I had 3 comments on the page it would show 3 3 3. However, when I use a limit in the comment entries tag such as 1, it would only count the 1 entry and not the total.
I’m not sure what I’m missing here, and I imagine there is a simple solution, which I can’t seem to find.
Thank you in advance for any suggestions or help you may have.
szgalbraith's avatar
szgalbraith
szgalbraith's avatar szgalbraith
Can you post an example of your code? Using the {comment_total} in your entries tag should work normally.
tomusa0106's avatar
tomusa0106
3 years ago
tomusa0106's avatar tomusa0106
The information you shared is very accurate, it gives me the knowledge that I need to learn. Thank you for sharing this useful information. contexto game
