Query Question
vw000's avatar
vw000
vw000's avatar vw000
Does Query: https://docs.expressionengine.com/latest/add-ons/query.html
Only work with EE native tables, or will it also work with custom tables and data I created manually on the database?
dougblackjr's avatar
dougblackjr
dougblackjr's avatar dougblackjr
It will work with non-EE native tables as well. You can also use EE models inside of an addon to access those
vw000's avatar
vw000
Thanks, that looks great. I will take a look.
vw000's avatar
vw000
I confirm this also works for non-EE tables. But for security reasons its only for SELECT queries. Which is still great for templates as no PHP is required.
I was looking at the EE Models that can also fetch data, and they can also save. But EE models are probably limited to only EE data. I was looking at saving data to my own created tables.
