Consent question hide after submitted
Wessel's avatar
Wessel
Wessel's avatar Wessel
Hi all,
How to define, that if visitor has submitted the form once, it won’t show up again? If i use sample code, it wil keep showing on the page.
There should be something by default like “if consent_submitted” or something, hope you’ll understand me. The alert functionality is only after submitting, so after reloading, or navigate to other page, i cannot use that function.
Thanks a lot!
{exp:consent:form}
   {consents}
     <fieldset>
       <dl>
         <dt>{consent_title}</dt>
         <dd>{consent_request}</dd>
       </dl>
       <label>
         <input type="radio" name="{consent_short_name}" value="y" {if consent_granted}checked{/if}>
         Toestaan
       </label>
       <label>
         <input type="radio" name="{consent_short_name}" value="n" {if ! consent_granted}checked{/if}>
         Weigeren
       </label>
     </fieldset>
   {/consents}
   <fieldset>
     <input type="submit" name="submit" value="Save">
   </fieldset>
{/exp:consent:form}
Chris's avatar
Chris
Chris's avatar Chris
You need to wrap your form in a conditional tag like the below:
{exp:consent:requests consent="your-consent-name"}
{if consent_granted == 1}
{!-- do nothing because they have already consented --}
{if:else}
{exp:consent:form consent="your-consent-name" return="{current_url}/"}
{!-- your fields here --}
{/exp:consent:form}
{/exp:consent:requests}
Wessel's avatar
Wessel
Hi Chris,
But when I have 3 consents… and they granted for 2 but declined 1… then it still show up with that option. There isn’t an ‘override’ tag that reminds if the consent form was submitted?
Thanks for quick response!
Chris's avatar
Chris
This sounds like what you’re looking for: [https://docs.expressionengine.com/latest/templates/globals/consent.html#checking-if-the-user-has-responded]
Wessel's avatar
Wessel
Hi Chris,
Looks like it works like it should! Thanks a lot, for others. This is the code i’ve used:
{if ! consent:has_responded:ee:cookies_performance}
<div>
<div>Cookies</div>
{exp:consent:form} {consents} <input checked="checked" name="{consent_short_name}" type="hidden" value="y" /> {/consents} <input name="submit" type="submit" value="Alles toestaan" /> <a href="#collapseCookie"> Zelf beheren </a> {/exp:consent:form}
<div>{exp:consent:form}
<div>{consents}
<div>
<div><strong>{consent_title}</strong></div>
<label> <input checked="checked" name="{consent_short_name}" type="radio" value="y" /> Toestaan </label> <label> <input checked="checked" name="{consent_short_name}" type="radio" value="n" /> Weigeren </label></div>
{/consents}</div>
<input name="submit" type="submit" value="Opslaan" /> {/exp:consent:form}</div>
</div>
? 1
