New Templates no longer showing in Templates files and local edits do not work
fanderson's avatar
fanderson
fanderson's avatar fanderson
I am building a new site using EE 6.06. I got everything set up with fields, channels, templates, partials, etc. and I was able to use my favorite IDE to edit the content and upload to the Template files on the server, but when I sat down to work today that connection no longer works. When I create new templates they do not show up in the Templates folder on the server side and when I make any edits to existing templates on my computer and try to upload them, the server does not recognize the changes. Template folder permissions is set to 777.
I checked in phpMyAdmin and new templates appear in the database but they do not show up in the Template files.
Fortunately I can edit in the EE control panel, but the convenience of editing in my IDE is lost.
Any clues what the solution to this dilemma might be? I have been building EE sites for more than ten years and have never seen anything like this.
ZealousWeb's avatar
ZealousWeb
ZealousWeb's avatar ZealousWeb
You have to check the config.php file and verify the below configuration.
$config['save_tmpl_files'] = 'y';
fanderson's avatar
fanderson
Confirmed. I have that in place and it still does not work.
Off the top of my head, I’d double check all of your paths. Beyond that, I know you mentioned the permissions on the template folder, I’d also check the individual templates real quick. Or run a recursive permissions set, just to make sure.
fanderson's avatar
fanderson
Alas, this we user error. I had multiple instances of $config[‘save_tmpl_files’] = ‘y’; in the config file. All is well now. Thanks.
