Unknown Model Error
dwatson's avatar
dwatson
dwatson's avatar dwatson
I posted an update to my site last April with no issues.
I went to post another update to my site the other day and I can’t get into the backend. When I go to /system, I see:
Exception Caught
Unknown model: ee:Config
DataStore.php:556
I’m not sure why I’m getting this error or how to fix it. Any suggestions?
Hi Dwatson,
What version of PHP and EE Are you running?
-Tom Jaeger
dwatson's avatar
dwatson
Hey Tom
I’m using PHP 7.3.28, MySQL 5.7.23-23. I am not sure which version of EE I have. I believe I upgraded to 6, then made my last post to my site. Is there a file I can open to see what version I have? I currently can’t get into the CMS, so I’m not sure where to look.
Yuri's avatar
Yuri
Yuri's avatar Yuri
I suggest you try some of the troubleshooting practices: https://docs.expressionengine.com/latest/troubleshooting/general.html#blank-pages
My suspect is that some of the files did not get updated/replaced properly, so you may try re-uploading everything (make sure you keep backup of your config file!)
Also as of EE5/6 it is recommended to use /admin.php as entry point to the control panel instead of /system directly
