Secure Cookies - Form Failures
xcl's avatar
xcl
xcl's avatar xcl
Would there be a reason that a form fails with ” This form has expired. Please refresh and try again.” when cookie_secure is set to y?
Removing the override in the config so that it is not secure submits without issue.
Is this a new issue, as in did you update the cookie settings and then try to send the form? If so, I’d try clearing all your cache and cookies and trying everything again.
xcl's avatar
xcl
xcl's avatar xcl
I tested that and the same problem.
New browser session with zero cookies. It picks up the new cookies with Secure = yes.
Any submission of any form gives that error.
Only when cookie_secure is set back to n does it work.
Is this any form on the front-end, but you can log in to the Control Panel and update entries, or is this any form anywhere? I don’t remember seeing this behavior anywhere, but trying to get all information for others who might have seen it.
xcl's avatar
xcl
xcl's avatar xcl
Only submission/contact forms on the websites.
Anything within the GUI/admin works just fine.
@xcl, any luck with this? Sorry I haven’t been able to follow up in the last few days.
xcl's avatar
xcl
xcl's avatar xcl
None i’m afraid.
Tried on new site with default config and see the same behaviour.
to be clear, you’re accessing the site using https and all of your assets, links, everything all link to https versions of your site, correct?
xcl's avatar
xcl
xcl's avatar xcl
Yes, we don’t use http:// at all.
The form is submissing to a secure page but no matter what, any submission when secure cookies are on, generate the standard EE page saying “This form has expired. Please refresh and try again”.
Is there any other way to debug this?
Sungod's avatar
Sungod
Sungod's avatar Sungod
Are you using Cloudflare? Are you using Tag caching?
Sungod's avatar
Sungod
I meant Template caching, edit of forum not working for me.
Sobral's avatar
Sobral
Sobral's avatar Sobral
Dumb question! Are the timezone settings right?
xcl's avatar
xcl
xcl's avatar xcl
@sungod - CF, no. Template caching, yes. I’ll try changing that.
@robson - I believe so, posting tests and updating pages gives the current localised time and that is to the second.
Is this a public-facing page that I can review? I’ve also shared this post over on the EECMS Slack in case others in the community have experienced this before.
xcl's avatar
xcl
xcl's avatar xcl
Not public at this time.
I’ve done a new install of EE on a different server (internal) and see the same very issue.
Is there anyway to debug this at all as even enabling that in the config and GUI gives no useful data.
1 2
