[SOLVED] A valid sender email is required
fanderson's avatar
fanderson
fanderson's avatar fanderson
I am setting up a new site with EE 6 and I am having trouble with the mail form. I have tried using PHP Mail and SMTP and both generate errors.
When I use PHP Mail I get the following error when I try and submit the form located here: http://kodiakco.us
“A valid sender email is required”
In the control panel I set email settings to use a domain specific email.
I would appreciate some help sorting this out.
Rob Allen's avatar
Rob Allen
Rob Allen's avatar Rob Allen
Have you included an email address in the form tag
{exp:email:contact_form user_recipients="no" recipients="[email protected]" charset="utf-8"}
fanderson's avatar
fanderson
Hi Rob,
Got it sorted out. I had changed the ‘from’ field to ‘email’ which messed it up. When I changed it to this everything worked fine:
<label for="from"></label>
        <input type="text" class="px-2" id="from" name="from" placeholder="Email*"  value="" />
