[SOLVED] substr does not work with PHP in templates
vw000's avatar
vw000
5 years ago
vw000's avatar vw000
Is there a way to use the PHP substr function in a template?
This for example works:
$var =  '{username}'
echo $var
It will output the EE username.
But I tried different variations with substr and similar replace PHP functions and they will not work. Instead of trimming my username, it actually just trims the variable and EE ignores the value.
Example:
$var =  '{username}'
$foo = substr($var, 5);
echo $foo;
This actually parses {username}, the variable instead of the actual username. It will output:
name}
It properly cut the first 5 characters, but not from my username, but the variable itself.
EE ignores the variables inside that string completely. I tried print, double quotes, and even using other PHP function to replace or cut the username. No luck.
vw000's avatar
vw000
5 years ago
Asked for help for this on Slack and I was told to use logged_in_username instead of username and it works!
It seems EE parses that variable differently for some reason.
Thanks to Blair from Slack for the suggestion.
