[SOLVED] Bug Report: CP Entry Manager not retaining sorted columns on pagination links
Mike Keller's avatar
Mike Keller
5 years ago
Mike Keller's avatar Mike Keller
Description of the problem Losing column sort after clicking pagination links in the CP entry manager.
How To Reproduce Steps to reproduce the behavior: Go to Entry Manager for channel with more than 25 entries Sort by any column (i.e. Status) Click Page 2 Notice your list is no longer sorted
Environment Details:
Version: [5.4.2] PHP Version [7.4] MySQL Version [5.6.43] OS: [Linux] Web Server: [Apache]
Possible Solution Need to retain the sort paramter within the $link variable when outputting the pagination urls. The following actually works: 1st sorted url on page 1 (sorted by status): /system/index.php?/cp/publish/edit&search_in=titles&perpage=25&search;=&sort_col=column_status&sort_dir=asc
If i simply append “&page=2” to that url, it works. i.e.: /system/index.php?/cp/publish/edit&search_in=titles&perpage=25&search;=&sort_col=column_status&sort_dir=asc&page=2
Default page2 or any page link url without doing the above is: /system/index.php?/cp/publish/edit&search_in=titles&perpage=25&search;=&sort_col=column_entry_date&sort_dir=desc
See the difference?
Hopefully this is an easy fix?
(This post is also on GitHub, but no reply as of today.)
5 years ago
Just posting link to Github issue for reference. https://github.com/ExpressionEngine/ExpressionEngine/issues/1057
5 years ago
Per the Github issue, this was resolved in 6.0.3 (the latest released version).
