Allow PHP? not working
News and General
realleoman's avatar
realleoman
about 5 years ago
realleoman's avatar realleoman
Has anyone experienced before having issues with the Allow PHP? option in the Templates section?
Suddenly, the server stopped recognizing the PHP code and it is now not able to show anything nor using custom PHP code in there.
For some reason, if I disable Allow PHP? template works again.
This is the main site: historico.zocalo.com.mx and this is the troubled URL => http://historico.zocalo.com.mx/seccion/category/tecnologia
Any help would be truly appreciated.
about 5 years ago
Is it possible that some of the PHP code in the template is breaking and thus causing the template parser to fail somewhere? I’d start by removing all PHP out of the template and enabling PHP to see if the template renders with PHP turned on, but no actual PHP included (make sure no PHP is in embedded templates, partials, or anything like that. If that works, then it’s pretty clear it’s something with the custom PHP. At that point I’d start adding back in small chunks until you discover the problem.
vw000's avatar
vw000
about 5 years ago
vw000's avatar vw000
As Andy said, this means something in your PHP code is probably crashing the whole template. Try to log in as admin and enable all the debug options to see the errors.
@realleoman were you able to resolve this issue?
