Unable to Access Add-Ons Section
Bluehaus 's avatar
Bluehaus
5 years ago
Bluehaus 's avatar Bluehaus
Hey Guys,
I was just updating an add-on (Structure) via FTP and when I went to log in to update via the Add-Ons section, I keep getting a “This page isn’t working” 500 error but only on that section. Everything else works perfectly. I’m a little stumped on this one. Any help would be greatly appreciated.
EE v6.0.3
Thanks in advance,
5 years ago
first try turning on debugging in your admin.php file by setting $debug = 1; . Hopefully that will show you the error that’s causing the 500 error.
Bluehaus 's avatar
Bluehaus
5 years ago
Hi Andy,
Thanks, I have enabled debugging but I’m not seeing any data being displayed. Obviously, not on the error page, but also not in the CMS once I go back and click around. I loaded up Chrome’s Inspect and did see the following in the Console:
Failed to load resource: the server responded with a status of 500 ()
VM82:5551 crbug/1173575, non-JS module files deprecated.
5 years ago
so you have $debug = 1; in your admin.php (assuming you’re using admin.php), but still getting the browser default 500 error message rather than a PHP error?
Next, I’d check your server’s error log for that site to see if there are errors logged there.
Of course, start with just deleting the structure files and trying to copy the files over again to make sure something didn’t get corrupted. you might even try re-downloading and extracting again.
Bluehaus 's avatar
Bluehaus
5 years ago
Correct
After renaming the Structures folders in all locations with a simple underscore before the folder name, things got interesting.
AREA: SYSTEM/USER/ADDONS
WHEN OLDER VERSION ENABLED
InvalidArgumentException Caught
No such property: 'session' on ExpressionEngine\Legacy\Facade
Facade.php:128
WHEN PREVIOUS VERSION ENABLED
error
Unable to load the following extension file:
ext.structure.php
WHEN LATEST VERSION ENABLED
HTTP ERROR 500
5 years ago
Well, the older and the previous versions make sense. You should get the Unable to load the following extension file: ext.structure.php on the latest version as well if you rename the add-on folder. We’re you able to check the server error logs and see if anything was in there? Somehow you need to find out what the error is that is causing the 500.
You might also try dev tools in chrome.
  • With the “Network” tab open and recording activity.
  • Go to your add-on’s page. You should see a request show up with a status of 500.
  • Click on that request and select the “Response” tab.
  • Hopefully there’s something there that shows an error in the response.
