use field in limit
captainahab's avatar
captainahab
captainahab's avatar captainahab
Hi, I need to set the limit in a channel entries tag with the value of a select – show 6|9|12 entries – field.
{exp:channel:entries channel="channelname" limit="{newscount}” {newscount} is a template partial with an entries tag and is rendered correctly when used outside the above entries tag. Looks like the channel entries tags are rendered at the same time and the limit variable is alway empty.
Thanks for any suggestion!
You’re correct in what the issue is. What you need to use is an embed vs a partial. A partial’s code is basically copied and pasted in the parent template and then the template is parsed. So you essentially end up with something like this the following, which is invalid.
    limit="{exp:channel:entries channel="anotherchannel"}...{/exp:channel:entries}"
An embed is parsed first, then the output of that will be parsed when the parent template is parsed.
captainahab
Hi Andy, thank you for your suggestion, unfortunately it does not work for me.
{embed="index/newscount"}
will return 12, but
{exp:channel:entries channel="news | otherchannel" search:show_in_news="not IS_EMPTY" limit='{embed="index/newscount"}' orderby="date" sort="desc" disable="category_fields|member_data|pagination|relationships"}
returns all entries for news | otherchannel.
try adding parse="inward" to the {exp:channel:entries channel="news | otherchannel"... tag
captainahab
Still not working.
hm. you’re right. I just tested this several ways and couldn’t get it to work. Can you share both your templates here. There might be a different approach here. The other option is if you’re handy with PHP at all, it might be worth it to write a quick add-on to do this.
captainahab
This is the template for the limit count, the field {news_total_count} is a select with key/value pairs.
{exp:channel:entries channel="homepage" disable="categories|category_fields|member_data|pagination|relationships"}
{news_total_count:value}
