How to calculate the sum of two field type values
m007's avatar
m007
about 5 years ago
m007's avatar m007
I have a channel with a field type used for numbers (called “price”) I want to show on one page all the entries for this channel, and at the end I want to calculate the amount of all values in that field, from all entries and the amount to be updated dynamically with each entry added. It’s that possible? Thanks
about 5 years ago
There’s no native way to do this with EE. You might be able to do this with Stash ( https://github.com/croxton/Stash ) and variables. However, I’d probably just do this with Javascript.
For a basic example, my template would look something like this:
{exp:channel:entries}
<span class="price">{price}</span>
Total Sum of Price: <span class="price-total"></span>
And then using jQuery, my Javascript would look like:
var i = 0;
$(".price").each(function () {
   i = parseFloat(i) + parseFloat($(this).data("price"));
$(".price-total").html(i);
hope this helps.
m007's avatar
m007
about 5 years ago
m007's avatar m007
Thanks Andy, I think I missed something because the calculated amount is not shown in page. The .price-total is a class?
about 5 years ago
ah . apparently, the code formatting isn’t working correctly. That should be
m007's avatar
m007
about 5 years ago
m007's avatar m007
Still not showing Require some external JavaScript?
about 5 years ago
To not assume anything. If you’re using my example exactly as is,
  • you need to include jQuery ( https://www.w3schools.com/jquery/jquery_get_started.asp )
  • jquery needs to be called before you use it in the template.
  • the javascript I included needs to be called after the DOM is loaded. $( window ).load(function() { ... }
m007's avatar
m007
about 5 years ago
m007's avatar m007
Still not working
This is the template <!DOCTYPE html> <html><head> <title> </title>
<!– jQuery –>
[removed][removed] </head> <body>
<div margin:0 auto; width:800px”> <div class=”uk-container uk-container-center”>
{exp:channel:entries channel="test" } {price} {/exp:channel:entries}
Total Sum of Price:
[removed] var i = 0;
$(“.price”).each(function () { i = parseFloat(i) + parseFloat($(this).data(“price”)); });
$(“.price-total”).html(i);[removed] </div> </div> </body></html>
and this is the result:
https://bazesportive.sibiu.ro/site/test
about 5 years ago
I don’t know why this keeps removing my markup, but the price is missing the data-attribute…
data-price="{price}"
about 5 years ago
I guess I should use gists instead: https://gist.github.com/ops-andy/ff81898f92b3bd23a9a583d56712366d
m007's avatar
m007
about 5 years ago
m007's avatar m007
Thank you from the bottom of my heart Andy, my appreciation
about 5 years ago
Happy to help!
