Displaying images from a fluid field
bijan's avatar
bijan
about 5 years ago
bijan's avatar bijan
Hello, I am fairly new to EE and I am testing out fluid fields. I tried reading through the documentation but was unable to solve my problem. I currently have a fluid field that can take in an image, however when I try and display that image nothing appears on the screen.
I am able to get text output, it’s just the image that I’m having problems with.
My current code is :
{exp:channel:entries channel="results"}
{fluid_field_test}
 {fluid_field_test:featured_image}
     {content}
   {content:featured_image}
     {/content}
   {/fluid_field_test:featured_image}
{/fluid_field_test}
Any help would be appreciated, thanks!
about 5 years ago
I think you’re really close. The fluid field is named ‘fluid_field_test’ and the file field is named ‘featured_image’ - right?
If so, try:
{fluid_field_test}
    {content}
      Extension: {extension}
      Upload date: {upload_date format="%Y %m %d"}
      URL: {url}
    {/content}
{/fluid_field_test}
bijan's avatar
bijan
about 5 years ago
Yes, the field names are ‘fluid_field_test’ and ‘featured_image’. Unfortunately, this code still doesn’t display the image. It does however grab the correct content for the extension/date/URL.
Rob Allen's avatar
Rob Allen
about 5 years ago
Rob Allen's avatar Rob Allen
That’s good because Robins code works - there’s no img tag in there.
Try this, I’ve replaced values with an image tag:
{fluid_field_test}
    {content}
      < img src="{url}" width="{width}" height="{height}" alt="{title}" >
    {/content}
{/fluid_field_test}
? 1
bijan's avatar
bijan
about 5 years ago
Hey there, thanks for this (it worked). You wouldn’t happen to know how to display from a fluid file grid, would you?
Rob Allen's avatar
Rob Allen
about 5 years ago
Sure, the file grid field has a reserved name for the file field, so if featured_image is the name of your file grid, you could do something like this:
{fluid_field_test}
    {content}
      < img src="{file}" width="{width}" height="{height}" alt="{title}" > // where {file} is the file grid file field name
    {/content}
{/fluid_field_test}
bijan's avatar
bijan
about 5 years ago
This didn’t seem to work for me. Not sure why. Is the file grid file field name always {file}? I tried a few different variations of what I thought it could be but no images are displayed.
{fluid_field_test}
    {fluid_field_test:fluid_file_grid}
    {content}
     < img src="{file}" width="{width}" height="{height}" alt="{title}"/ >
    {/content}
   {/fluid_field_test:fluid_file_grid}
{/fluid_field_test}
bijan's avatar
bijan
I figured this out by the way, the answer for anyone that may need it:
<figure> {exp:channel:entries channel="CHANNEL-NAME"}
{ FIELD-NAME }
 < img src="{FIELD-NAME:file}" >
{ /FIELD-NAME }
{/exp:channel:entries} </figure>
